Java web browser source code
Java programming topics
Post by Nipuna » Thu Sep 22, 2011 12:48 pm
I found the source code of a basic Java web browser.
Here it is
I added without syntax highlighting because if I do so there would be star marks withing the code.
import java.awt.*;
import java.awt.event.*;
import java.util.*;
import java.net.*;
import java.io.*;
import javax.swing.*;
import javax.swing.event.*;
public class WebBrowser
     public static void main(String [] args)
          JFrame frame = new EditorPaneFrame();
          frame.show();
class EditorPaneFrame extends JFrame
     private JTextField url;
     private JCheckBox editable;
     private JButton loadButton;
     private JButton backButton;
     private JEditorPane editorPane;
     private Stack urlStack = new Stack();
     public EditorPaneFrame()
          setTitle("Java Web Browser");
          setSize(600,400);
          addWindowListener(new WindowAdapter()
               public void windowClosing(WindowEvent e)
                    System.exit(0);
          // set up text field and load button for typing in URL
          url = new JTextField(30);
          loadButton = new JButton("Load");
          loadButton.addActionListener(new ActionListener()
               public void actionPerformed(ActionEvent event)
                    try
                         // remember URL for back button
                         urlStack.push(url.getText());
                         editorPane.setPage(url.getText());
                    catch(Exception e)
                         editorPane.setText("Error: " +e);
          // set up back button and button action
          backButton = new JButton("Back");
          backButton.addActionListener(new ActionListener()
                    if(urlStack.size()<=1) return;
                    try
                         urlStack.pop();
                         String urlString = (String)urlStack.peek();
                         url.setText(urlString);
                         editorPane.setPage(urlString);
                    catch(IOException e)
                         editorPane.setText("Error : " +e);
          editorPane = new JEditorPane();
          editorPane.setEditable(false);
          editorPane.addHyperlinkListener(new HyperlinkListener()
               public void hyperlinkUpdate(HyperlinkEvent event)
                    if(event.getEventType() == HyperlinkEvent.EventType.ACTIVATED)
                         try
                              urlStack.push(event.getURL().toString());
                              url.setText(event.getURL().toString());
                              editorPane.setPage(event.getURL());
                              editorPane.setText("Error: " + e);
          editable = new JCheckBox();
          editable.addActionListener(new ActionListener()
                    editorPane.setEditable(editable.isSelected());
          Container contentPane = getContentPane();
          contentPane.add(new JScrollPane(editorPane), "Center");
          JPanel panel = new JPanel();
          panel.add(new JLabel("URL"));
          panel.add(url);
          panel.add(loadButton);
          panel.add(backButton);
          panel.add(new JLabel("Editable"));
          panel.add(editable);
          contentPane.add(panel,"South");
Return to “Java Programming”
