How to import a certificate to Java Key Store (JKS)
Java programming topics
Post by Saman » Thu Nov 11, 2010 6:37 pm
  1. First we need to prepare the private key and certificate in DER format. Usually we have them in plain format such as PEM as below.
    -----BEGIN CERTIFICATE-----
    MIIF1jCCBL6gAwIBAgIHKzDzMq1TIjANBgkqhkiG9
    w0BAQUFADCByjELMAkGA1UEkEPuDa6PsFscQA==
    -----END CERTIFICATE-----
    Say you have key.pem and cert.pem as your private key and certificate files (in PEM format).
    openssl pkcs8 -topk8 -nocrypt -in key.pem -inform PEM -out key.der -outform DER
    openssl x509 -in cert.pem -inform PEM -out cert.der -outform DER
    Now you have key.DER and cert.DER created with you.
  2. Next download the attached file.
    ImportKey.zip
    (3.97 KiB) Downloaded 638 times
    It includes both the source and a class file. You can use the class file for now.
  3. Run the following command as below to import these files to JKS.
    user@host:~$ java ImportKey key.der cert.der
    Output:
    Using keystore-file : /home/user/keystore.ImportKey
    One certificate, no chain.
    Key and certificate stored.
    Alias:importkey  Password:importkey
    Now we have a proper JKS containing our private key and certificate in a file called keystore.ImportKey, using 'importkey' as alias and also as password. For any further changes, like changing the password we can use keytool.
  4. You can change password using following commands.
    keytool -storepasswd -keystore /root/keystore.ImportKey
    Enter importkey as current password and enter your new password 2 times.
    keytool -keypasswd -alias importkey -keystore /root/keystore.ImportKey
    Enter the new password you put in the previous step, then enter importkey once. After that you are allowed the provide the new password. Enter the same two times.
  5. Now you need to add certificate authority. Lets assume you use GoDaddy.
    Download the CA certificate using,
    wget –no-check-certificate https://certificates.godaddy.com/repository/sf_issuing.crt
    Add that to your key file using following command.
    keytool -import -alias intermed -file sf_issuing.crt -keystore /root/keystore -storepass changeit -trustcacerts
Re: How to import a certificate to Java Key Store (JKS)
Post by Nipuna » Thu Nov 11, 2010 7:32 pm
Friend you are Doing a Great Service for Us.
I Learned about how to make an text out put from Java from your Previous Post.
Return to “Java Programming”
