import java.util.Scanner;
class methodCalc
	public static void menu()
		System.out.println("1) Add");
		System.out.println("2) Subtract");
		System.out.println("3) Multiply");
		System.out.println("4) Divide");
		System.out.println("5) Quit");
	public static void main(String[]args)
		Scanner input = new Scanner(System.in);
		int option=0;
		while (option!=5)
			menu();
			System.out.println("\nPlease choose an option from the menu.");
			System.out.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~");
			option = input.nextInt();
			if (option==1 || option==2 || option==3 || option==4)
				System.out.println("Please enter your first number.");
				int num1 = input.nextInt();
				System.out.println("Please enter your second number.");
				int num2 = input.nextInt();
				System.out.println("~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~");
				if (option==1)
					int a = Add(num1,num2);
					System.out.print(num1+" + "+num2);
					System.out.print(" = " + a);
					System.out.println("\n================================\n");
				if (option==2)
					int a = Sub(num1,num2);
					System.out.print(num1+" - "+num2);
				if (option==3)
					int a = Multi(num1,num2);
					System.out.print(num1+" * "+num2);
				if (option==4)
					int a = Div(num1,num2);
					System.out.print(num1+" / "+num2);
			else
				System.out.println("\nSorry, I do not recognise that input.\n");
		System.out.println("Thank you, come again");
	public static int Add(int num1,int num2)
		return(num1+num2);
	public static int Sub(int num1,int num2)
		return(num1-num2);
	public static int Multi(int num1,int num2)
		return(num1*num2);
	public static int Div(int num1,int num2)
		return(num1/num2);
 lolol
  lolol
 that should have jumped out at me!
