How to run a Java Class from scratch
Java programming topics
Post by Neo » Sun Apr 18, 2010 12:55 am
I had to write a Java program to help a member of ours. I didn't touch Java after 2003 and I couldn't remember the essential settings. So I had to surf the net to find out how we can compile and run a Java class file. So I thought it would be better to add a quick guide to do this from scratch.
  1. Download Java Development Kit (JDK).
  2. Set paths - You better copy below code to a batch file (.bat) to run before compiling and running a Java program.
    set path=C:\Java\jdk1.6.0_20\bin
    set CLASSPATH=.;C:\Java\jdk1.6.0_20\lib
    set JAVA_HOME=C:\Java\jdk1.6.0_20
  3. Compile a Java program - use following command
    C:\Java\jdk1.6.0_20\bin\javac.exe Hello.java
    Sample Java code is give below. Save following contents to Hello.java
    public class Hello {
         public static void main(String argv[]) {
              System.out.println("Hello world !");
    After this step, you can see a file named as Hello.class
  4. Running the class file - use following command
    C:\Java\jdk1.6.0_20\bin\java.exe Hello.class
That's it! I hope you will be able to run your first Java program.
Re: How to run a Java Class from scratch
Post by Nipuna » Mon Feb 21, 2011 12:19 pm
Neo friend
I did as this
http://www.java.com/en/download/help/path.xml
http://www.ehow.com/how_5127784_set-java-path.html
Then I don't have to Type Java Compiler Path again and again.
We can use Simple by typing
javac
in Command Prompt
If some one wants more info Just search on Google like this " set java path "
I added this to Help for others and Not tried to Show that I Know More than You. Don't misunderstand Me !
Return to “Java Programming”
