* Author: Tim Desjardins
* Copyright (c) 2008 Agwego Enterprises Inc.
* Feel free to use or abuse this code anyway you wish, without warranty of course. */
* getMacAddresses - return all mac addresses found
* @return array of strings (mac addresses) empty if none found
public static String [] getMacAddresses()
try {
Enumeration<NetworkInterface> nis = NetworkInterface.getNetworkInterfaces();
ArrayList<String> macs = new ArrayList<String>();
while( nis.hasMoreElements() ) {
String mac = macToString( nis.nextElement() );
// not all interface will have a mac address for instance loopback on windows
if( mac != null ) {
macs.add( mac );
return macs.toArray( new String[0] );
} catch( SocketException ex ) {
System.err.println( "SocketException:: " + ex.getMessage() );
ex.printStackTrace();
} catch( Exception ex ) {
System.err.println( "Exception:: " + ex.getMessage() );
return new String[0];
* @param sep - use a different separator
public static void setSep( String sep )
try {
MacAddressApplet.sep = sep;
// don't care
* @param format - the output format string for bytes that can be overridden default hex.
public static void setFormat( String format )
try {
MacAddressApplet.format = format;
// don't care
public static void main( String... args )
System.err.println( " MacAddress = " + getMacAddress() );
setSep( "-" );
String macs [] = getMacAddresses();
for( String mac : macs )
System.err.println( " MacAddresses = " + mac );
setSep( ":" );
System.err.println( " MacAddresses JSON = " + getMacAddressesJSON() );
<html>
<head></head>
<body>
<a href="" onclick="macs.getMacAddress();"> Get "first" MAC Address</a>
<br/>
<br/>
<a href="" onclick="macs.getMacAddressesJSON();"> Get all MAC Addresses</a>
<!--[if !IE]> Firefox and others will use outer object -->
<embed type="application/x-java-applet"
name="macaddressapplet"
width="0"
height="0"
code="MacAddressApplet"
archive="macaddressapplet.jar"
pluginspage="http://java.sun.com/javase/downloads/index.jsp"
style="position:absolute; top:-1000px; left:-1000px;">
<noembed>
<!--<![endif]-->
<object classid="clsid:CAFEEFAC-0016-0000-FFFF-ABCDEFFEDCBA"
<param name="code" value="MacAddressApplet">
<param name="archive" value="macaddressapplet.jar" >
<param name="mayscript" value="true">
<param name="scriptable" value="true">
<param name="width" value="0">
<param name="height" value="0">
</object>
</noembed>
</embed>
<!--<![endif]-->
<script type="text/javascript">
var macs = {
getMacAddress : function()
document.macaddressapplet.setSep( "-" );
alert( "Mac Address = " + document.macaddressapplet.getMacAddress() );
getMacAddressesJSON : function()
document.macaddressapplet.setSep( ":" );
document.macaddressapplet.setFormat( "%02x" );
var macs = eval( String( document.macaddressapplet.getMacAddressesJSON() ) );
var mac_string = "";
for( var idx = 0; idx < macs.length; idx ++ )
mac_string += "\t" + macs[ idx ] + "\n ";
alert( "Mac Addresses = \n" + mac_string );
</script>
</body>
</html>
