Ahhh thanks for the help.I will re install it & try. I can run it with NetBeams.But I can't run it with out Netbeans.
I install it & then i could see it on open with dialog box.
But When I try to run .jar file.It open sudden & get close.NIPUNA did you test it.?Can you please tell me how it work & how to test it ? (Think that I can't test my own code )
NEo I tried that.But Still got the same problem.When I double click the .jar file.Command prompt displays & suddenly get lost.
But I can test the program with NetBeans.What should I do with this?
