JAVA for beginner
Java programming topics
Re: JAVA for beginner
Post by Neo » Mon Nov 01, 2010 8:11 pm
I only run JRE (Java Runtime Environment) on my PC as I don't do Java development. I though this is enough to run NetBeans but it seems we need to install JDK (Java Development KIT). I have no idea why NetBeans require JDK since it is going to install one next on the installation.
Anyway, as NetBean installation states, go to http://java.sun.com/javase/downloads and download the JDK. I think you will have to register first. After the installation, you will find a folder (normally within Program Files) named as JDK x.x.x (version). Browse this folder to the installation.
Good luck!!!!
Post by Neo » Mon Nov 01, 2010 8:24 pm
See page http://netbeans.org/community/releases/69/install.html
The Java SE Development Kit (JDK) 6.0 Update 13 or later is required to install NetBeans IDE. The 6.9.1 version of the IDE can not be installed using JDK 5.0. You can download the latest update of JDK 6.0 at http://java.sun.com/javase/downloads.
The PHP, Ruby and C/C++ NetBeans bundles only require the Java Runtime Environment (JRE) 6 to be installed and run. However, if you are planning to use any of the Java features, you need JDK 6.0.
So if we use Java with NetBeans, JDK is required. Otherwise only JRE is needed.
Post by Face » Mon Nov 01, 2010 8:25 pm
I am downloading It now.NEO.75.89MB.
Download JDK & reg.png (29.8 KiB) Viewed 10081 times
Download JDK & reg2.png (23.07 KiB) Viewed 10081 times
Download JDK & reg3.png (34.92 KiB) Viewed 10081 times
Post by Face » Mon Nov 01, 2010 9:17 pm
I got JDK & installed it.
JDK 6 instl 1 ec.png (41.47 KiB) Viewed 10079 times
JDK 6 instl 2 ec.png (49.02 KiB) Viewed 10079 times
JDK 6 instl 3 ec.png (48.41 KiB) Viewed 10079 times
I got JDK & then try to do in Netbean.
Install NETBEAN 5 ok ec.png (47 KiB) Viewed 10079 times
Install NETBEAN 6 ec.png (43.54 KiB) Viewed 10079 times
Install NETBEAN 7 ec.png (46.22 KiB) Viewed 10079 times
Install NETBEAN 8 ec.png (42.98 KiB) Viewed 10079 times
Install NETBEAN 9 ec.png (69.75 KiB) Viewed 10079 times
Now I have NETBEAN in my PC.I wish to start Now.
Post by Face » Mon Nov 01, 2010 11:53 pm
friends This is my first JAVA in NETBEAN.
first JAVA ec.png (108.65 KiB) Viewed 10075 times
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package myfirstjava;
 * @author GAYAN
public class Main {
     * @param args the command line arguments
    public static void main(String[] args) {
        System.out.println("I will learn JAVA");
        // TODO code application logic here
Return to “Java Programming”
