Update Online Database using GSM/GPRS Shield
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Sun Jul 13, 2014 10:16 pm
මේ තියෙන EFCom GPRS/GSM Shield එක පාවිච්චි කරලා online database එකකට data insert වෙන විදිහට හදාගන්නේ කොහොමද?
lakindu93
Sergeant
Sergeant
Re: Update Online Database using GSM/GPRS Shield
Post by lakindu93 » Tue Jul 15, 2014 4:24 am
reply soon....
Post by Neo » Sun Jul 20, 2014 10:21 am
First you need to study the AT command sequence required to connect to a url and submit data. Then you need write a server side code on your web server to intercept those calls and store data to your database.
You need to contact your seller and ask him to provide you the AT command reference manual for the chip/module you have bought.
If your chip/module is listed in TRONIC.LK, you may contact them to get some help, no matter you bought it from them or not.
Good luck!
Post by Neo » Sun Jul 20, 2014 12:19 pm
Found the right source for you. Have a look at following link.
http://www.elecfreaks.com/wiki/index.ph ... GSM_Shield
You can find SIM900_AT Command Manual_V1.03 at the end of the page under References. That's all need to get you started.
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Mon Jul 21, 2014 9:26 pm
Neo wrote:First you need to study the AT command sequence required to connect to a url and submit data. Then you need write a server side code on your web server to intercept those calls and store data to your database.
Good luck!
thanks for your Reply...
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Mon Jul 21, 2014 9:27 pm
Neo wrote:Found the right source for you. Have a look at following link.
yes... we are going to use this module...
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Mon Jul 21, 2014 10:24 pm
are there any tutorials about AT commands to connect a url and submit data ?
Post by Neo » Tue Jul 22, 2014 1:13 am
Have a look at section "7 AT Commands for GPRS Support" in the AT commands manual. You can also follow the links below if you are using an Arduino.
https://robot.lk/viewtopic.php?f=18&t=4350
https://robot.lk/viewtopic.php?f=18&t=4348
https://robot.lk/viewtopic.php?f=18&t=4349
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Tue Jul 22, 2014 6:14 pm
thanks lot... I will see
lakindu93
Sergeant
Sergeant
Post by lakindu93 » Sun Aug 31, 2014 11:26 am
Any one know about how to get the GSM BTS location using AT Commands....(like cell info display in mobile phones)
I'm using SIM900 Efcom GSM/GPRS Shield..
Return to “Arduino”
