Sample code TCP/UDP network using SIM900 and Arduino
Post by Saman » Mon Feb 03, 2014 11:21 pm
Single client
 *  Description: This example shows how to configure the GPRS module in single
 *  client mode and open a TCP socket as client. This example only shows the
 *  AT commands (and the answers of the module) used to open a TCP/UDP
 *  connection. For more information about the AT commands, refer to
 *  the AT command manual.
 *  Copyright (C) 2013 Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version 0.2
 *  Author: Alejandro Gallego
int8_t answer;
int onModulePin= 2;
char aux_str[50];
char ip_data[40]="Test string from GPRS shield\r\n";
void setup(){
    pinMode(onModulePin, OUTPUT);
    Serial.begin(115200);
    Serial.println("Starting...");
    power_on();
    delay(3000);
    // sets the PIN code
    sendATcommand2("AT+CPIN=****", "OK", "ERROR", 2000);
    delay(3000);
    Serial.println("Connecting to the network...");
    while( sendATcommand2("AT+CREG?", "+CREG: 0,1", "+CREG: 0,5", 1000)== 0 );
void loop(){
    // Selects Single-connection mode
    if (sendATcommand2("AT+CIPMUX=0", "OK", "ERROR", 1000) == 1)
        // Waits for status IP INITIAL
        while(sendATcommand2("AT+CIPSTATUS", "INITIAL", "", 500)  == 0 );
        delay(5000);
        // Sets the APN, user name and password
        if (sendATcommand2("AT+CSTT=\"APN\",\"user_name\",\"password\"", "OK",  "ERROR", 30000) == 1)
            // Waits for status IP START
            while(sendATcommand2("AT+CIPSTATUS", "START", "", 500)  == 0 );
            delay(5000);
            // Brings Up Wireless Connection
            if (sendATcommand2("AT+CIICR", "OK", "ERROR", 30000) == 1)
                // Waits for status IP GPRSACT
                while(sendATcommand2("AT+CIPSTATUS", "GPRSACT", "", 500)  == 0 );
                delay(5000);
                // Gets Local IP Address
                if (sendATcommand2("AT+CIFSR", ".", "ERROR", 10000) == 1)
                    // Waits for status IP STATUS
                    while(sendATcommand2("AT+CIPSTATUS", "IP STATUS", "", 500)  == 0 );
                    delay(5000);
                    Serial.println("Openning TCP");
                    // Opens a TCP socket
                    if (sendATcommand2("AT+CIPSTART=\"TCP\",\"IP_address\",\"port\"",
                            "CONNECT OK", "CONNECT FAIL", 30000) == 1)
                        Serial.println("Connected");
                        // Sends some data to the TCP socket
                        sprintf(aux_str,"AT+CIPSEND=%d", strlen(ip_data));
                        if (sendATcommand2(aux_str, ">", "ERROR", 10000) == 1)
                            sendATcommand2(ip_data, "SEND OK", "ERROR", 10000);
                        // Closes the socket
                        sendATcommand2("AT+CIPCLOSE", "CLOSE OK", "ERROR", 10000);
                    else
                        Serial.println("Error openning the connection");
                else
                    Serial.println("Error getting the IP address");
            else
                Serial.println("Error bring up wireless connection");
        else
            Serial.println("Error setting the APN");
    else
        Serial.println("Error setting the single connection");
    sendATcommand2("AT+CIPSHUT", "OK", "ERROR", 10000);
    delay(10000);
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand2("AT", "OK", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){     // Send AT every two seconds and wait for the answer
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
        char* expected_answer2, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        // if there are data in the UART input buffer, reads it and checks for the asnwer
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // check if the desired answer 1  is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
            // check if the desired answer 2 is in the response of the module
            else if (strstr(response, expected_answer2) != NULL)
                answer = 2;
    // Waits for the asnwer with time out
    while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
Multiple clients
 *  Description: This example shows how to configure the GPRS module in multi
 *  Version 0.2
int8_t answer;
int onModulePin= 2;
char aux_str[50];
void setup(){
    power_on();
    delay(3000);
    delay(3000);
    while( sendATcommand2("AT+CREG?", "+CREG: 0,1", "+CREG: 0,5", 1000) == 0 );
void loop(){
    // Selects Multi-connection mode
    if (sendATcommand2("AT+CIPMUX=1", "OK", "ERROR", 1000) == 1)
        delay(5000);
            delay(5000);
                delay(5000);
                    delay(5000);
                    // Opens a TCP socket with connection 1
                    if (sendATcommand2("AT+CIPSTART=1,\"TCP\",\"IP_address\",\"port\"",
                        sprintf(aux_str,"AT+CIPSEND=1,%d", strlen(ip_data));
                            delay(500);
                        sendATcommand2("AT+CIPCLOSE=1", "CLOSE OK", "ERROR", 10000);
                    else
                        Serial.println("Error openning the connection 1");
                else
            else
        else
    else
        Serial.println("Error setting the multi-connection");
    delay(10000);
void power_on(){
    uint8_t answer=0;
    if (answer == 0)
        // power on pulse
        delay(3000);
    char response[100];
    delay(100);
    x = 0;
    do{
            x++;
                answer = 1;
                answer = 2;
    return answer;
Re: Sample code TCP/UDP network using SIM900 and Arduino
Post by Saman » Mon Feb 03, 2014 11:25 pm
AT commandResponseDescription
AT+CIPMUX= OKSelects single connection (0) or multiple connection (1)
AT+CSTT="myAPN"OKSets APN
AT+CIICRBrings up wireless connection
AT+CIFSRGet local IP address
AT+CIPSTARTEstablishes a connection with a server.
AT+CIPSENDSends data when the a connection is established.
AT+CIPCLOSECloses the connection
Return to “Arduino”
