Sample code to take a call using SIM900 and Arduino
Post by Saman » Mon Feb 03, 2014 10:54 pm
The code example and the connection diagram shown below are used to originate a voice call and, pushing a button, end that voice call. The button is connected between digital pin 12 an ground. A 10kΩ pull-up resistor is needed at this pin.
 *  Description: This example does a call and hangs it when a button has pressed.
 *  This example only shows the AT commands (and the answers of the module) used
 *  to do a call. For more information about the AT commands, refer to the AT
 *  command manual.
 *  Copyright (C) 2013 Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version 0.2
 *  Author: Alejandro Gallego
int8_t answer;
int onModulePin = 2;
int button = 12;
char aux_str[30];
char phone_number[]="*********";     // ********* is the number to call
void setup(){
    pinMode(onModulePin, OUTPUT);
    pinMode(button, INPUT);
    Serial.begin(115200);
    Serial.println("Starting...");
    power_on();
    delay(3000);
    // sets the PIN code
    sendATcommand("AT+CPIN=****", "OK", 2000);
    delay(3000);
    Serial.println("Connecting to the network...");
    while( (sendATcommand("AT+CREG?", "+CREG: 0,1", 500) ||
            sendATcommand("AT+CREG?", "+CREG: 0,5", 500)) == 0 );
    sprintf(aux_str, "ATD%s;", phone_number);
    sendATcommand(aux_str, "OK", 10000);
    // press the button for hang the call
    while(digitalRead(button)==1);
    Serial.println("ATH");            // disconnects the existing call
void loop(){
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){     // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
    x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){
            // if there are data in the UART input buffer, reads it and checks for the asnwer
            response[x] = Serial.read();
            x++;
            // check if the desired answer  is in the response of the module
            if (strstr(response, expected_answer) != NULL)
                answer = 1;
         // Waits for the asnwer with time out
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
To make a lost call:
 *  Description: This example does a lostcall. This example only shows the AT
 *  commands (and the answers of the module) used to do a lostcall. For more
 *  information about the AT commands, refer to the AT command manual.
 *  Version 0.2
int8_t answer;
int seconds = 20;
char aux_str[30];
void setup(){
    power_on();
    delay(3000);
    delay(3000);
    delay(seconds * 1000);
void loop(){
void power_on(){
    uint8_t answer=0;
    if (answer == 0)
        // power on pulse
        delay(3000);
    char response[100];
    delay(100);
    x = 0;
    do{
            x++;
                answer = 1;
    return answer;
Re: Sample code to take a call using SIM900 and Arduino
Post by Saman » Mon Feb 03, 2014 11:05 pm
CommandResponseDescription
ATD*********;********* is the number to call.
ATAOKAnswer an incoming call.
ATHOKCancel voice calls
Return to “Arduino”
