MCU Based Peak Power Tracker Solar Charger(70W,100W)
nwclasantha
Post by nwclasantha » Thu May 02, 2013 7:16 pm
MCU Based Peak Power Tracker Solar Charger (70W,100W)
???? MOSFET ?? ?? ??????? Ring Inductor ????? ????? ??? ????? ????? ???? ?????? ?? High Current MOSFETs ???? ???? ?? 100W/300W ?? ??? ???? ??? ?????? ?????? ??? ?????? ??? ???????.????? ???? D.C Output Voltage ?? ??? ???????? ??? ????? Circuite ??? ?????? ????? ???? ?? .
Solar Panel ?? ????? ?? ??????? ?? D.C. ??????? ?????? ?? ??????? D.C. Output ???? ??? ???? Charge Controller ?? ???????? ..!
Charge Controller ??? ?????? Solar Panel ?? ????? ?? D.C. ??????? ?????? Battery Pack ????? ???? ?? ?? Inverter ???? ?????? ????? . Inverter ?? ????? D.C. ??????? A.C. 230V - 50 Hz ??? ????? ????. ????????? Charge Controller ?? Peak Power Tracker ??? ????? ????? ???????????? Solar Panel ?? ????? ?? ??????? ?? D.C. ??????? Battery Pack ????? ???? ????? ????????? ????????????? ???????? ????.
??? ????????? Inverter ??? ???????? ????? ??????? ??? ??? Generator ???? ???????? ?? ??? ????????? ????? ?????/???????? Generator ????? Solar Panel ????? ??? ??????? ????? ??????? Battery Pack ????? ???? ?? ?????? D.C. ??????? ???? ??? ??? Generator ?? ??????????? ???? ??????? ????? .
??? ?????????? ?? ????????? ?????? ??? ????? TRONIC.LK ?????? ???? ?????? ????? ?????? ??? ?????? ???? Arduino Development Board ?? ?? ..! ?? ?? ??? ?????? Charge Controller ?????? ???????? ??? ??????? ??? ????? ?? ??? ???? Coding, Circuite Diagram, PCB ?? ??? Watts ??? ???? ??? ????? ???? ???? ??? ???? ????? ?? .
????????? ?????? ??????? ????? ??????? ??????? 1Ohm 10W resister ???? ????? ????? ??? V=I*R ???? ???? ?????? Comparator ???? ????? ?? ??????? Analog to Digital ??????? ?? ???? Micro Controller ???? ??????? ?? Bord ??? ??? ???? ?? ?????.! ???? ????????? ??? Analog to Digital Convertor ?????? ????? ? ??? ??????? .???? ???? ?? Micro Controller ???? ??????? ?? Bord ?? ????? USART to Ethernet ??? ???? Module ???? ????? ?????? ?????? ????? ????????? ??? ????? ?? ?????.! ???? ????????? ??? ?????? ?? ???? SMS ?????? ????? ????????? ?? ??????? ?????? ???? ???? ??????? ??? ?????? ???????? ?? ????? .
ArduinoSolar.pdf
Complete Coding.txt
MCU Based Peak Power Tracker Solar Charger .pdf
Herath
Re: MCU Based Peak Power Tracker Solar Charger(70W,100W)
Post by Herath » Thu May 02, 2013 9:40 pm
It is interesting to see articles talking about Solar energy. But it is hard to find solar panels. Were you able to build a system or are these just articles?. :)
I am wanting to try solar, but can't seem to find the panels to begin with. Not looking for a total replacement of the grid but to supplement.
nwclasantha
Post by nwclasantha » Thu May 02, 2013 9:56 pm
Herath wrote:It is interesting to see articles talking about Solar energy. But it is hard to find solar panels. Were you able to build a system or are these just articles?. :)
It is proper to test with this peak power tracker unit with variable input D.C. source accordingly. otherwise you just find a solar panel to test that asap. finally you can have yr own multi purpose Emulator whrere already wittern in C# language with rs 232 access through a dll.bez i have my own work bench which is supporting USB,RS232 as well asa Ethernet actually.
SemiconductorCat
Post by SemiconductorCat » Thu May 02, 2013 10:05 pm
Your implementation is based on the state machines, this a descrete one. Pretty hard coded right.
LMIN_SOL_WATTS to 5 watts , and etc etc..
Anyway this is not the pure dynamic implementation of MPPT algorithm. It's a binary search like
algorithm where it divides the search space by 2 and it's time complexity is lg(N).
Anyway I like your code. Only disadvantage is when somebody plug a different solar cell into your
design , he need to change the firmware values, cos it does not calculate it dynamically. I'm not
bugging anybody here, but with little study or review of that white paper, you could easily implement it.
Or change this existing code to work according to that.
This is like a reflexive agent, but will work with the solar cell that you planing. Problem is when somebody
connected another solar cell. that's I told this is hardcoded. Anyway one little simple effort. I'm not familiar with
arduno but your code is easy to read anyway. So I can't introduce a patch into this, I could not bug the author
at all.So nice work, but need some little more effort. There's no magic in that white paper.
I love state machine based implementation, keep up good coding.
And you could use [ code ] You Code [ / code ] tags.
like bellow -V
void run_charger(void) {
  static int off_count = OFF_NUM;
  switch (charger_state) {
    case on:
      if (sol_watts < MIN_SOL_WATTS) {              //if watts input from the solar panel is less than
        charger_state = off;                        //the minimum solar watts then it is getting dark so
        off_count = OFF_NUM;                        //go to the charger off state
        TURN_OFF_MOSFETS;
      else if (bat_volts > MAX_BAT_VOLTS) {        //else if the battery voltage has gotten above the float
        charger_state = bat_float;                 //battery float voltage go to the charger battery float state
      else if (sol_watts < LOW_SOL_WATTS) {        //else if the solar input watts is less than low solar watts
        pwm = PWM_MAX;                             //it means there is not much power being generated by the solar panel
        set_pwm_duty();			            //so we just set the pwm = 100% so we can get as much of this power as possible
      }                                            //and stay in the charger on state
      else {
        pwm = ((bat_volts * 10) / (sol_volts / 10)) + 5;  //else if we are making more power than low solar watts figure out what the pwm
        charger_state = bulk;                              //value should be and change the charger to bulk state
      break;
    case bulk:
        TURN_OFF_MOSFETS;
        charger_state = on;                      //it means there is not much power being generated by the solar panel
        TURN_ON_MOSFETS;                         //so go to charger on state
      else {                                     // this is where we do the Peak Power Tracking ro Maximum Power Point algorithm
        if (old_sol_watts >= sol_watts) {        //  if previous watts are greater change the value of
          delta = -delta;			// delta to make pwm increase or decrease to maximize watts
        pwm += delta;                           // add delta to change PWM duty cycle for PPT algorythm
        old_sol_watts = sol_watts;              // load old_watts with current watts value for next time
        set_pwm_duty();				// set pwm duty cycle to pwm value
      break;
    case bat_float:
        set_pwm_duty();
        TURN_OFF_MOSFETS;
      else if (bat_volts > MAX_BAT_VOLTS) {    //since we're in the battery float state if the battery voltage
        pwm -= 1;                               //is above the float voltage back off the pwm to lower it
        set_pwm_duty();
      else if (bat_volts < MAX_BAT_VOLTS) {    //else if the battery voltage is less than the float voltage
        pwm += 1;                              //increment the pwm to get it back up to the float voltage
        set_pwm_duty();
        if (pwm >= 100) {                      //if pwm gets up to 100 it means we can't keep the battery at
          charger_state = bulk;                //float voltage so jump to charger bulk state to charge the battery
      break;
    case off:                                  //when we jump into the charger off state, off_count is set with OFF_NUM
      if (off_count > 0) {                     //this means that we run through the off state OFF_NUM of times with out doing
        off_count--;                           //anything, this is to allow the battery voltage to settle down to see if the
      }                                        //battery has been disconnected
      else if ((bat_volts > HIGH_BAT_VOLTS) && (bat_volts < MAX_BAT_VOLTS) && (sol_volts > bat_volts)) {
        charger_state = bat_float;              //if battery voltage is still high and solar volts are high
        set_pwm_duty();		                //change charger state to battery float
        TURN_ON_MOSFETS;
      else if ((bat_volts > MIN_BAT_VOLTS) && (bat_volts < MAX_BAT_VOLTS) && (sol_volts > bat_volts)) {
        pwm = PWM_START;                        //if battery volts aren't quite so high but we have solar volts
        set_pwm_duty();				//greater than battery volts showing it is day light then
        charger_state = on;                     //change charger state to on so we start charging
        TURN_ON_MOSFETS;
      }                                          //else stay in the off state
      break;
    default:
      TURN_OFF_MOSFETS;
      break;
Return to “Arduino”
