interfaces are open specifications.
Here is a project on programming PIC18F2550 with an arduno board: .
https://sites.google.com/site/thehighsp ... ino-pic18f
And here is the microchip's 18FXXX programming specification.
http://ww1.microchip.com/downloads/en/D ... 39622L.pdf
The windows/linux program is still a command based version. You could go and read the code. I do encourage reading
other's code. It was open source and I'll be free to put it in here.
Copyright (C) 2012 kirill Kulakov
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include "rs232.h"
#include "HEX.h"
#include <stdio.h>
#include <stdlib.h>
#include <conio.h>
#define DEVICE_DELAY 150
void main(){
printf("Arduino as A PIC18f2550 programmer - Version 0.2 - http://goo.gl/fyd9mn\n");
if(_main()){
printf("Error! can not continue\n");
printf("Make sure you have uploaded the sketch to the Arduino,\nconnected the chip correctly and using a valid HEX file\n");
else {
printf("The chip was programmed successfully!\n");
system("pause");
int _main(){
HEX thehex;
char buf[4096],key;
int n;
unsigned int address=0,i,j;
int comPort=-1;
//reading the hex file
printf("Enter location of hex file: ");
scanf("%4096[^\n]",buf);
if( (thehex = readHex(buf)) == NULL ){
printf("Can not open the file\n");
return 1;
printf("---------------------------\n");
printf("Connecting to the Arduino...");
for(i=0;i<16;i++){
if(!OpenComport(i, 9600)){
for(j=0;j<10;j++){
SendBuf(2,(unsigned char *)"DX",strlen("DX"));
n = PollComport(2, (unsigned char *)buf, 4095);
Sleep(DEVICE_DELAY);
if( *buf == 'T' || *buf == 'F' ){
comPort = i;
break;
CloseComport(2);
if( comPort != -1 )
break;
if( comPort == -1 ){
printf("Cannot connect to the programmer");
return 1;
OpenComport(comPort, 9600);
printf("Success!\nConnecting to the chip...");
//wait for 18f2550
do{
if( SendBuf(comPort,(unsigned char *)"DX",strlen("DX")) == -1 ) return 1;
n = PollComport(comPort, (unsigned char *)buf, 4095);
}while( n == 0 || *buf != 'T' );
printf("Success!\n");
printf("Erasing the chip...");
//chip reset
if( SendBuf(comPort,(unsigned char *)"EX",strlen("EX")) == -1 ) return 1;
printf("Programming fuse bits...");
for(i=0;i<0xf;i++){
if(fuseChanged(thehex,i)){
sprintf(buf,"C%X%02XX",i,getfuse(thehex,i));
SendBuf(comPort,(unsigned char *)buf,strlen(buf));
printf("Programming flash memory...");
//memory write
while( address < 0x8000 ){
for(i=0;i<0x20;i++){
if( getData(thehex,address+i) != 0xff ){
sprintf(buf,"W");
sprintf(buf+strlen(buf),"%04X",address);
for(i=0;i<0x20;i++)
sprintf(buf+strlen(buf),"%02X",getData(thehex,address+i));
sprintf(buf+strlen(buf),"X\n");
break;
address += 0x20;
CloseComport(2);
return 0;
them on their original repository. See bottom links reference.
And this is what arduno does. Many people think it's arduno "C". But it's wrong. it's not "C" , but it's a "C" like language.
Neither it's extension ends with ".C" but with ".ino". But it's easier to go through the code and understand.
Happy code digging.
// I wrote it according to the following datasheet:
// http://ww1.microchip.com/downloads/en/DeviceDoc/39622L.pdf
//pin out config
#define PGC 6
#define PGD 5
//#define EN 7 //PGM & MCLR
#define PGM 8
#define MCLR 7
#define P15 1
#define P12 1
String inputString = "";
boolean stringComplete = false;
unsigned long temp;
byte buffer[32];
byte address[3];
void setup(){
Serial.begin(9600);
pinMode(PGC,OUTPUT);
pinMode(PGD,OUTPUT);
pinMode(PGM,OUTPUT);
pinMode(MCLR,OUTPUT);
inputString.reserve(200);
void loop(){
//turn on the chip (disable programming mode & diable reset)
digitalWrite(PGM,LOW);
digitalWrite(MCLR,HIGH);
//////THE MAIN CODE///////////
void serialEvent() {
while (Serial.available()) {
char inChar = (char)Serial.read();
if (inChar == 'X') { //buffering till X
stringComplete = true;
break;
inputString += inChar;
if (stringComplete && inputString.charAt(0) == 'W'){ //WRITE
if(inputString.length() != 69) {
//Serial.println("Input is wrong, should be: W<address - 4 digit><32bytes>X");
nullString();
goto endofthisif;
address[2] = 0;
address[1] = char2byte(inputString.charAt(2),inputString.charAt(1));
address[0] = char2byte(inputString.charAt(4),inputString.charAt(3));
nullBuffer(); // set everything FF
for(int i=0;i<32;i++){
buffer[i] = char2byte(inputString.charAt(2*i+6),inputString.charAt(2*i+5));
nullString();
// print address
//Serial.print("Programming 32bytes,starting at:");
//Serial.print("0x00");
//if(address[1]<0x10) Serial.print("0"); Serial.print(address[1],HEX);
//if(address[0]<0x10) Serial.print("0"); Serial.println(address[0],HEX);
//for(int i=0;i<32;i++) { Serial.print(buffer[i],HEX); }
//Serial.println("");
///Write
digitalWrite(PGM,HIGH);
delay(1);
programBuffer(address[2],address[1],address[0]);
digitalWrite(MCLR,LOW);
//Serial.println("Programming complety");
endofthisif:;
if (stringComplete && inputString.charAt(0) == 'E'){ //Erase all
delay(1);
////erase
erase_all();
//Serial.println("Erase complety");
nullString();
if (stringComplete && inputString.charAt(0) == 'R'){ //READ
address[2] = char2byte(inputString.charAt(2),inputString.charAt(1));
address[1] = char2byte(inputString.charAt(4),inputString.charAt(3));
address[0] = char2byte(inputString.charAt(6),inputString.charAt(5));
//read
temp=0;
temp = ((long)address[2])<<(16); //doesn't work with out (long)
temp |= ((long)address[1])<<(8);
temp |= (long)address[0];
Serial.print(temp,HEX); Serial.print(":");
delay(1);
address[2] = byte( (temp&0xFF0000)>>16 );
address[1] = byte( (temp&0xFF00)>>8 );
address[0] = byte( temp&0xFF );
Serial.print(readFlash(address[2],address[1],address[0]),HEX);
Serial.print(" ");
temp++;
Serial.println("");
nullString();
if (stringComplete && inputString.charAt(0) == 'C'){ //config
delay(1);
configWrite( char2byte(inputString.charAt(1),'0'),char2byte(inputString.charAt(3),inputString.charAt(2)) );
nullString();
if (stringComplete && inputString.charAt(0) == 'D'){ //config
if( checkIf_pic18f2550() ){
delay(100); Serial.print("T");
} else {
delay(100); Serial.print("F");
nullString();
//clear string incase the first CHAR isn't E,R,W
if(inputString.charAt(0) != 'E' && inputString.charAt(0) != 'R' && inputString.charAt(0) != 'W' && inputString.charAt(0) != 'C' && inputString.charAt(0) != 'D') nullString();
byte readFlash(byte usb,byte msb,byte lsb){
byte value=0;
send4bitcommand(B0000);
send16bit( 0x0e00 | usb ); //
send16bit(0x6ef8);
send16bit( 0x0e00 | msb ); //
send16bit(0x6ef7);
send16bit( 0x0e00 | lsb ); //
send16bit(0x6ef6);
send4bitcommand(B1000); //
pinMode(PGD,INPUT); digitalWrite(PGD,LOW);
for(byte i=0;i<8;i++){ //read
digitalWrite(PGC,HIGH);
digitalWrite(PGC,LOW);
for(byte i=0;i<8;i++){ //shift out
if(digitalRead(PGD) == HIGH) value += 1<<i; //sample PGD
return value;
void send4bitcommand(byte data){
for(byte i=0;i<4;i++){
if( (1<<i) & data ) digitalWrite(PGD,HIGH); else digitalWrite(PGD,LOW);
void send16bit(unsigned int data){
for(byte i=0;i<16;i++){
void erase_all(){ //for some reason the chip stops respone, just reconnect voltage
send16bit(0x0e3c); //
send16bit(0x6ef8);
send16bit(0x0e00); //
send16bit(0x6ef7);
send16bit(0x0e05); //
send16bit(0x6ef6);
send4bitcommand(B1100);
send16bit(0x3F3F);
send16bit(0x6ef8);
send16bit(0x6ef7);
send16bit(0x0e04); //
send16bit(0x6ef6);
send16bit(0x8F8F);
send4bitcommand(B0000); //
send16bit(0x0000); //
delay(2);
delay(2);
delay(2);
void configWrite(byte address,byte data){
send16bit( 0x8ea6 );
send16bit( 0x8ca6 );
send16bit( 0x0e30 ); //
send16bit(0x6ef8);
send16bit( 0x0e00 ); //
send16bit(0x6ef7);
send16bit( 0x0e00 | address ); //
send16bit(0x6ef6);
//Serial.println("programming");
send4bitcommand(B1111);
if(address&0x01) send16bit( 0x0000 | data<<8 ); // if even MSB ignored, LSB read
else send16bit( 0x0000 | data ); // if odd MSB read, LSB ignored
delay(1);
delayMicroseconds(100);
send16bit(0x0000);
void programBuffer(byte usb,byte msb,byte lsb){
if( (lsb&0x0F) | ((lsb&0xF0)>>4)%2){
//Serial.println("Error: First digit (refere as HEX) have to be 0, and the second digit have to be even.");
//Serial.println("valid examples: 0x000000 , 0x000060, 0x006320, 0x0063E0");
//Serial.println("INvalid examples: 0x000004 , 0x000014, 0x006328, 0x0063EA");
//Serial.println("0,2,4,6,8,A,C,E are even");
return;
//step 1
send16bit(0x8ea6);
send16bit(0x9ca6);
//step 2
send16bit(0x6ef8);
send16bit(0x6ef7);
send16bit(0x6ef6);
//step 3
for(byte i=0;i<15;i++){
send4bitcommand(B1101);
send16bit( buffer[(2*i)+1]<<8 | buffer[(i*2)] );
//step 4
send16bit( buffer[31]<<8 | buffer[30] );
//nop
delay(1);
send16bit(0x0000);
//done
//nothing special underhere:
void nullString(){
inputString = "";
void nullBuffer(){
for(byte i=0;i<32;i++) buffer[i] = 0xFF;
byte char2byte(char lsb,char msb){
byte result=0;
switch(lsb){
case '0': result = 0; break;
case '1': result = 1; break;
case '2': result = 2; break;
case '3': result = 3; break;
case '4': result = 4; break;
case '5': result = 5; break;
case '6': result = 6; break;
case '7': result = 7; break;
case '8': result = 8; break;
case '9': result = 9; break;
case 'A': result = 0xA; break;
case 'B': result = 0xB; break;
case 'C': result = 0xC; break;
case 'D': result = 0xD; break;
case 'E': result = 0xE; break;
case 'F': result = 0xF; break;
switch(msb){
case '0': result |= 0<<4; break;
case '1': result |= 1<<4; break;
case '2': result |= 2<<4; break;
case '3': result |= 3<<4; break;
case '4': result |= 4<<4; break;
case '5': result |= 5<<4; break;
case '6': result |= 6<<4; break;
case '7': result |= 7<<4; break;
case '8': result |= 8<<4; break;
case '9': result |= 9<<4; break;
case 'A': result |= 0xA<<4; break;
case 'B': result |= 0xB<<4; break;
case 'C': result |= 0xC<<4; break;
case 'D': result |= 0xD<<4; break;
case 'E': result |= 0xE<<4; break;
case 'F': result |= 0xF<<4; break;
return result;
int checkIf_pic18f2550(){
delay(1);
if( readFlash(0x3f,0xff,0xff) == 0x12 )
return 1;
else
return 0;
Reference links:
* main project : https://sites.google.com/site/thehighsp ... ino-pic18f
* microchip programming specification: http://ww1.microchip.com/downloads/en/D ... 39622L.pdf
* code repository : https://bitbucket.org/kirill578/arduino ... ?at=master
Happy Reading the Code.
