If you have a Nokia 5110 LCD Display module such as the one in TRONIC.LK as below, and you need to connect it to an Arduino or another type of microcontroller based development module, here is a quick guide which will help you out.
Connection Diagram:
Datasheet:
Example Driver Code:
Connecting Nokia 5110 LCD Display Module to microcontroller
- Attachments
- 2.jpg (44.23 KiB) Viewed 9876 times
- nomaansuun
Re: Connecting Nokia 5110 LCD Display Module to microcontroller
This is the type of information that should be shared around the web.
