System.IO.Path.GetTempPath
System.IO.Path.GetTempFileName
Private Function GetTempFile() As String
Dim folder As String = Path.Combine(Path.GetTempPath, Path.GetRandomFileName)
Do While Directory.Exists(folder)
folder = Path.Combine(Path.GetTempPath, Path.GetRandomFileName)
Loop
Return folder
End FunctionCreating a temp file using a GUID
Dim folder As String = Path.Combine(Path.GetTempPath, Guid.NewGuid.ToString)
folder = Path.Combine(Path.GetTempPath, Guid.NewGuid.ToString)
Loop
Return folder
End Function
