How to pass controls from one form to another using C#
.NET programming topics
Post by Neo » Sun Feb 07, 2010 2:24 am
There are several methods. The easiest is to write a public property on Form2 to pass the string of the test box as in following example.
public string MyTestBox {
	get {return textbox1.Text;}
	set {textbox1.Text = value;}
Now add the following code to Form1. Then you are able to access the controls of Form2 by using above method.
Form2 form2;
public Form1()
	InitializeComponent();
private void Form1_Load(object sender, EventArgs e)
	form2 = new Form2();
	form2.Show();
private void button1_Click(object sender, EventArgs e)
	MessageBox.Show(form2.MyTestBox);
Herath
Re: How to pass controls from one form to another using C#
Post by Herath » Sun Jul 24, 2011 2:13 pm
In Form2 I have,
	private void trackBar1_Scroll(object sender, EventArgs e)
		Form1 f = (Form1)this.Owner;
		f.Controls["textBox1"].Text = trackBar1.Value.ToString();
I am showing the Form2 as a child form of Form1. This also seem to work fine. I was expecting a invalid cross threading error. :). But not getting any due to this child and parent connection (same tread i guess).
cthread.rar
(24.75 KiB) Downloaded 872 times
Reason: Tabs are placed as indents to syntax
Post by Neo » Sun Jul 24, 2011 4:23 pm
Cool :)
Return to “.NET Programming”
