- Open the Macros IDE (Tools - Macros - Macros IDE)
- Create a new module, name it to CollapseAll, replace the code in the created file with the posted source code, save file
- Assign keys in VS.Net (Tools - Options - Keyboard)
Imports System
Imports EnvDTE
Imports EnvDTE80
Imports System.Diagnostics
Public Module CollapseAll
Sub CollapseAll()
' Get the the Solution Explorer tree
Dim UIHSolutionExplorer As UIHierarchy
UIHSolutionExplorer = DTE.Windows.Item(Constants.vsext_wk_SProjectWindow).Object()
' Check if there is any open solution
If (UIHSolutionExplorer.UIHierarchyItems.Count = 0) Then
' MsgBox("Nothing to collapse. You must have an open solution.")
Return
End If
' Get the top node (the name of the solution)
Dim UIHSolutionRootNode As UIHierarchyItem
UIHSolutionRootNode = UIHSolutionExplorer.UIHierarchyItems.Item(1)
' Collapse each project node
Dim UIHItem As UIHierarchyItem
For Each UIHItem In UIHSolutionRootNode.UIHierarchyItems
UIHItem.UIHierarchyItems.Expanded = False
Next
' Select the solution node, or else when you click
' on the solution window
' scrollbar, it will synchronize the open document
' with the tree and pop
' out the corresponding node which is probably not what you want.
UIHSolutionRootNode.Select(vsUISelectionType.vsUISelectionTypeSelect)
End Sub
End Module
